I have a DSO3034A an I want to remote control it using a simple tcp socket and Scpi-raw.
I can actually do execute scpi commands without a problem, I can even requests the learn string using ":SYST:SET?".
But the problem is I don't seem to be able to set it back. In the documentation it is mentioned that I should send it back with ":SYST:SET " and after that following the data.
One of the examples I tried :
:SYST:SET #800083042 expandMode 0,"ground" wfmAntialiasing
more data
It seemed straight forward but I have no success with it until now.
Can someone help me with this, say me what I do wrong ?
I use TcpClient with c# to handle the socket communication.
Thank,
Peter
more data
Thank,
Peter
If you have the Keysight Connection Expert installed, you can use its IOMonitor to see what your program actually sent and debug the problem.
