I am plotting a computed variable ft vs another simulated variable I. the plot came out as a scatter set of points that is hard to follow.
I tried to change the trace type to linear but the plot remained as a scattered set of points. Could you please explain why and how
I can (if I can!) force trace type to be linear. I attached the dataset I am using. I am plotting fs vs I_Probe2.i
Thanks
Samir
Thanks
Samir
