Hello All.
I am having trouble with an Excel workbook with a VBA macro that has been given to me by a customer.
The macro is supposed to set up a 3458a from some user input and then continue data logging.
When I run the macro I get the error 'compile error: error loading dll'
The error highlights on a line call for agtRM.dll. ( Agilent Visa COM resource manager 1).
I have checked VBA references where there are no missing references. Agilent Visa COM resource manager is found and points to the correct directory. Also, if I retype the line the code will auto-complete.
Has anyone come across this problem? How can I fix it?
my setup:
3458a DMM
82357B USB/GPIB
Keysight IO libraries suite 17
windows 7 32bit and 64bit ( I have tried on different machines)
MS office 2010 pro.
my setup:
3458a DMM
82357B USB/GPIB
MS office 2010 pro.
The name your calling in your code has changed in newer revs of I/O libs, generally when I open a resource manager and a session to an instrument in VBA it looks like this:
Dim RM As New VisaComLib.ResourceManager
Dim DMM As New VisaComLib.FormattedIO488
Set DMM.IO = RM.Open("GPIB0::22::INSTR")
