ADS has been really frustrating me up by continuously giving this error when I try to open my designs:
(debootcb.ael line 2121, column 18)
Error opening library "Design_CDRX_PCBs_lib", cell "Detector_PCB_H_Ch", view "layout".
Corrupted database encountered: design Design_CDRX_PCBs_lib/Detector_PCB_H_Ch/layout
It does NOT happen during the same run (or even on the same day). Rather it happens after 2-3 runs. Also, it is NOT specific to Layout views only. It even happens to Schematic and Symbol views.
Can someone please give a way to avert this error once and for all?
Regards
Edited by: ali_cmi on Feb 19, 2015 10:03 PM
Regards
I was also sceptical when ADS changed to the new database concept expecting this kind of errors.
But even with some crashes I have never seen a corupted database so far.
In several cases the lock on a design was not removed, but this is not really an issue.
Have you checked your system on stability ?
- Harddisk (checkdisk, Smart data), Main memory (Memory test), CPU (Prime95)?
I guess you have checked the (debootcb.ael line 2121, column 18) already and this does not show anything interesting ?
Hermann
