*Dear Keysight Engineer:*
*Our university updated ADS2015.01 and Cadence IC616 . The urgent requirement is how to setup the dynamic link with this two software or how could we find help both technical or document.*
*Thanks a lot in advance.*
ECE HKUST
If possible , please contact us by email : mzhaoab@ust.hk
ECE HKUST
I have another problem. I setup ADS2014 dynamic and run idfConfigCadence for setting ADS in cadence.
However, after I execute IC616 dynamic to launch ADS2014. And, I instance the view and try to run simulation under ADS environment. The netlist in xxx_wrk/.DL/xxx.net is open circuit.
here is an example. there is nothing in test circuit.
define test (n1 n2)
end test
Could you please help to find why I got open circuit?
Thanks.
