Dear all,
Here is what I'd like to achieve: I have a .s2p file and I want to import this file into ADS and make a "component" using it. Eventually I am going to use this component in a circuit and conduct AC sweeps in ADS.
Is this possible? And if is, could you please let me the steps to do that?
Thank you so much in advance!
Just enter file name.
Since you mention AC sweeps, which sounds like low frequency simulations, be sure to verify that the S2P file has data points around your desired frequencies.
