I'm confused by the firmware date for A.09.20.08 being 29Sep2010, yet the later version number A.09.22.12 is dated earlier as 13Aug2010.
I'm assuming the date on A.09.20.08 is incorrect, or basically my question is which is the latest version? the latest date, or the latest version number.
Thanks!
Thanks!
Thanks!
9.20.08 was an emergency fix for 9.20.06 which had a memory leak. Because this was causing problems and because the fix was a trivial one-line addition, we drastically shortened the test time which is why the date is so recent. The code is really based upon the 9.20.06 build which was 5/11/2010
