How do you set offset to the measured power?
I measure LTE ACPR for 100W power amplifier at 30dBm Pout and I use on the input 35dB external safety attenuator. The problem is that the carrier power show lower value then it should be due to my safety attenuation. I do not see any setting in the Spectrum Analyzer that offset the power in LTE mode.
If I am in standard Spectrum Analyzer mod you can offset the power in Amplitude setting. That setting is blank if you go to LTE ACPR.
Any other way to offset the power.
Regards.
Regards.
