I am sending successive waveforms - as my measurement progresses - to the same plot window, where I display them together using the "next curve" pin.
Since at the end I will have A LOT of them (even 100 or more) I wanted to have each new one in a slightly different color, to see at a glance some changes...
Unfortunately I cannot find out how to do it! Any help?
Alessandro
Alessandro
Edited by: Kevin001 on Aug 19, 2014 7:05 AM
After some warnings of interfaces in instrument config file not enabled (for GPIB-VISA, ASRL), I got a warning for +ignoring unknown keyword "eoiEnabled"+, and finally an error for +Mismatch error: expected property, got EnableColorCoding, error n.640+.
I fear my version is just too old but - just in case - could you describe the procedure so that I can try to replicate it, since I know that the "traces" control pin is available ?
I've cleared the program's instrument list as this isn't required here. I've also taken a screenshot of the program's detail view. Hopefully this will work for you.
Kevin
Kevin
Kevin
Kevin
-Bill
