I added a second HP6624 to a single module 3070 III running 8.40p. When I alter the test head config file to add the supply it results in not being able to load a test plan (see below). The program throws a Windows error 20011. If the second line below is commented out, and the file is recompiled, the test plan loads without issue.
supplies hp6624 1 to 4 asru channels 1 to 4
supplies hp6624 5 to 6 asru channels 5 to 6
We have a UNIX based 3070 in which we added a second HP6244 successfully many years ago without any issues.
Anyone have any ideas why this happens?
Thanks
Thanks
In another venue it was suggested that the 6624A will not work as a second supply in a single module Windows system; however, a 6621A should.
Any Agilent people have any input?
