I use a Network analyzer 8753C with a S-parameter Test Set 85046A. I only know how to change the output RF power. Does anyone knows that is it possible to change the output voltage?
I use an oscilloscope to measure the output voltage of the network analyzer. And when I set the output power of the network analyzer to its maximum, +20 dBm, the peak-to-peak voltage is 2.7 V at 100 MHz. This pp voltage decreases as the frequency increases. 1.35 pp voltage at 500MHz.
I'd like to use some higher pp voltage as 6 volts. Does any one know how to achieve that?
Thanks a lot! :P
Thanks a lot! :P
If you need only 6vp-p, then a .1watt to 1 watt amplifier should be enough. W=((Vrms^2)/50) Just make sure you do not exceed any maximum limits of your test equipment.
