I am using an Agilent 33500B waveform generator. I used Command Expert to write code for c#.
I am having trouble with the Phase command, both in Command Expert when i run the script, and in c#. Both give "Unable to Format Parameter".
Here's the c# code:
double Angle_Trigger = 0;
Ag33500B_33600A v33510B = new Ag33500B_33600A("USB0::0x0957::0x2607::MY52200463::INSTR");
v33510B.SCPI.SOURce.BURSt.PHASe.Command(1u, 0.0);
v33510B.SCPI.SOURce.BURSt.PHASe.Command(2u, Angle_Trigger);
Both versions of the phase command give the error.
Thanks for any help.
Here's the c# code:
