I want to measure a switch with 9 ports full cross over for a frequency range about 300 MHz to 6 GHz with 1601 points.
The problem is, that I can´t measure because the Makro of agilent generate too much chanels for the NWA.
(for example: 48 channels and 7 traces)
How can I solve this problem without splitting my measurement :?: :?: :?:
Thanks for comment`s
Br
andré
Br
andré
I was able to setup a 9 port full crossbar setup where I measured all 36 possible forward transmission paths (didn't setup reverse) and all 9 reflection parameters with 10 channels and a max trace count of 10 with 1601 points.
