N6762A Current Turn on Priority
Question asked by Cynthia Employee on Sep 21, 2014
Latest reply on Oct 17, 2014 by MattC
I read from the datasheet that N6762A have current turn on priority. I need the SCPI command to set N6762A to turn on current output instead of voltage output. Could you assist?
From what I read from the user manual, it seems that the command FUNC CURR, (@channel) is only applicable for N678x. Can I use this same command for N6762A? Or do you have other command to set this?
Thanks.
Cynthia
