I'm trying to use an excel sheet as a "configuration sheet" that has configuration data for the program I'm running in VEE.
I already have the VEE program opening the appropriate excel sheet and reading the data in as a 2D array.
What is the easiest way to take this array of data and populate many different "set variables" with individual data?
(about 20 different values i.e.:
min time
max time
min temp
max temp
min voltage
max voltage
min current
... etc.)
Thanks in advance for your help!
min time
max time
min temp
max temp
min voltage
max voltage
min current
... etc.)
I was trying to do the very same thing today and came up with this. I dont know how fast it will execute if it is constantly pulling data out of the database but it sure is a lot easier to have it look for a name of a test value instead of trying to pinpoint it to a cell location that may change in the future. No need to keep track of where that data is located! So take a look, it may be too basic for some but it seems to work.
Kurt
