Bit Order and Data Format question for N9320B through GPIB
Question asked by nrowell92 on Dec 27, 2013
Latest reply on Jan 20, 2014 by fanfansimon
I am working on updating some old code for GPIB communication protocols where we used a swapped bit order to record data from a trace. We also used a 32 bit real data format as opposed to ASCII. Does anyone know of a way to set the bit order to swapped or set the real data format to 32 bits as it does not see it as a compatible parameter. The current communication sequence is listed below. Thanks.
:FORM:TRAC:DATA REAL,32
:FORM:BORD SWAP
:TRAC:DATA? TRACE1
