Hi everyone,
I just bought a DSO1072B Oscilloscope and it is working fine, but the LCD display colors of the channels seems to me a little bit odd, since CH1 is NOT yellow (it seem like reddish) and CH2 is NOT green (it is a little bit blueish) and they are hard to read due to low contrast.
But when I save the waveform and open it on the computer, as the one attached, the colors are right.
Is there a way to fix that in software? Or will I have to contact technical support?
Al
