New user looking for help programming this power supply with Labview... I have installed the Labview driver and can turn the supply on and off. However, I cannot configure the output voltage and current with the supplied Labview VI's. I am getting an error # 11 on the front panel of the power supply.
Do you still have this issue? You may want to check to see what programming language your 6632B is set to using the SYST:LANG command. The 6632B has both SCPI and an old, in house programming language included on it.
