Hello
I am using the N9020A MXA Signal Analyzer to measure GFSK modulated signals. The results for FSK error is somehow not calculated correct when a meas-filter included. See attached screenshot. The reference signal seem not filtered. How can I set up the analyzer to include the meas-filter in the FSK error measurement?
Best regards
Sono
Best regards
Sono
I do not have a good response for you via the Agilent Discussion Forum. I suggest you contact your local Agilent Technical Contact Center for assistance.
In the Americas: Contact us for general technical support. Toll-free:1 800 829-4444 Press #, then 2 fax:1 800 829-4433 hours: 8:00 am - 8:00 pm ET, Mon - Fri
Thank you -
