Is it possible to perform a MATH function using a reference waveform? I am wanting to look at the difference between two waveforms but it isn't possible to view both live at the same time so the plan was to capture the first and store as a reference and then run a MATH function between that and the second live waveform but I can't get this to work. Any ideas or suggestions welcomed.
Al
