The Agilent website says specifically that the 10073A and 10073B probes are intended for use with the 54616B scope, and I'm currently using a 10073A with my 54616B.
I plan to purchase another probe and what I'd like to know is:
are the 10073C and 10073D probes compatible with the 54616B scope?
From their specs it looks like they would be, but if someone knows the answer for sure I'd really appreciate hearing it.
Thank you.
Thank you.
Al
