Hello.
We have some HP Agilent equipment.
Some days ago We receive on our HP 8664a error.
After power on 8664a start calibration procedure and when it's finished on display shows Error code 3,503,310. After calibration diagnostic LEDs doesn't show any error. Power LEDs doesn't show any errors.
Message:
Hardware failure 3
(Sometimes)Hardware failure 6
Calibration error 2
After Special Function 170 Result Error code 2,459,310.
We connect power meter (R&S NRP-Z11) to 8664 and when We setup 0dB - 8664 give - 23dB. Power meter are calibrated. Attenuator (Options 015 and 075) was checked separately and they are in working condition.
Questions:
1. What's this error indicate? Please answer more detailed.
2. How We can repair this fault? We haven't schematic diagrams.
We're private company and we have great engineers and technical knowledge(Our experience in radiocommunication over 30 years). Also We have any equipment for solve any problems.
We're waiting for a fast reply.
Best regards, Anatoliy.
Message:
Hardware failure 3
Calibration error 2
Questions:
I would recommend running self test 320 this is a more thorough test. Refer to manual page 2a-3 to run this A16 SW1 Bit 1 or A needs to be set to 1 to run this test.
This usually points to a specific module that is suspected as faulty. The only other advise I can give is I have found units that have a low battery so the cal data is corrupt or missing.
Before chasing a failure. Allow unit to warm up then try running test 171 Recal. I have seen this fix many things by itself. check controller board battery.
Joe Lubecky
Test Equipment Plus
