I'm using LabView 2012 to remote control the Agilent AWG N8241A. I've found LabView drivers on ni.com. They are using library: AGN6030A.dll. The problem starts when I try to send a waveform to the device:
Error -1074126844 occurred at AGN6030A Create Arbitrary Waveform.vi
Possible reason(s):
Driver Status: (Hex 0xBFFA2004) The function generator's waveform memory is full.
Primary Error: (Hex 0xBFFA000C) Attribute ID not recognized.
I can't understand it because I clear the device's memory before sending the new waveform. Do you know where I can find the application note for this library?
Any help would be appreciated.
Hubert
Possible reason(s):
Hubert
