Recently I bought a 83595A for my 8510C . The system has currently a 83594A , which performs good . The 83595A have not
enough power for the 8510C . I need the service manuals of both items . I will try first to calibrate the 83595A to achieve
more power . If this fail , I will try to build a functional item from both 83594A and 83595A .
Many Thanks for answer from Franz
While I realize you want to use this on a network analyzer, this post should be resubmitted to the Sources forum:
Signal Generators and Sources - General Use
