schematic and symbol pin naming and checking
Question asked by bruceyang on Jul 11, 2014
Latest reply on Jul 11, 2014 by aehoward
Coming from Cadence side, I am lost on how to get pin name customized.
In cadence, you just place pins and name them whatever you want, and then use "create a cellview --from cellview" then a symbol is generated with same pin namings.
In ADS, seems you can only use sequential numbers, is this true?
also, in cadence, you just check and save to find connectivity problems. Seems in ADS, the "check design" report simply miss a lot of unconnected pins (it seems only make sure number of pins to match).
