I have several U1272A's at my disposal and would like to automatically get readings from them. I have enough IR-USB adapters and they indeed show up as serial devices.
My question is: How do I get measurements/readings from the U1272A? The goal being to automate measurements, into an excel sheet (but a broader compatibility is wanted).
I understand these devices support a sub-set of the SCPI commands and if I send them one to the correct COM port, I should get an appropriate response. In fact, it does work (sometimes) when sending *IDN?.
Is there a list of the commands support specifically by this multimeter? I've looked a lot and never could find an exhaustive list of commands (be it for this particular device or SCPI in general).
I have installed the Agilent IO Suite as well as Agilent Command Expert. With these, I can use the Interactive IO to send and read commands (only, as I do not know the commands I don't get much other than *IDN?). I have tried using the Command Expert panel in Excel by registering the device, but it seems I cannot connect to the device (even if it shows up in the Command Expert standalone).
Any help would be greatly appreciated as materials regarding this is quite scarce.
If you are some sort of a software Guru, check this APP for answers.
