I have an E5071B model. It was not used for a month. It has been working well a month ago. When it was turned on today, after Windows system was started up, it has the following error message and the operation interface could not open:
The installer has encountered an unexpected error installing this package. This many indicate a problem with this package. The error code is 2356.
What could cause this error? How can I fix it?
Thank you very much for the help,
Min
Min
You could also try the built in System Recovery of the Windows partition. This is discussed in ENA's Service Guide's Appendix B.
E5071B Service Guide:
http://cp.literature.agilent.com/litweb ... -90370.pdf
ENA Support Website:
http://www.agilent.com/find/ena_support
