Hello everybody!
I have my ENA 5071B connected to a PC by a LAN connection. I am developing a VB6 program to control the ENA measurements.
I want to transfer a TXT file from the PC to a certain folder of the ENA. Is it possible? Should I use the ":MMEM:TRAN" command? How should I use it?
Thank you in advance.
http://ena.tm.agilent.com/e5071c/manual ... _files.htm
