Hello.
I’m focusing on the error of relative frequency measurement of N9020A in counter mode, while the frequency of input signal fluctuates in the positive direction. For example, first I placed the marker on f0. Then I measured the relative frequency (f1- f0) by using the marker delta. Because there was a time interval in the two steps, and the frequency would change in the measurement process. Assuming that during the period of the second step, f0 changed from f0 to (f0+Δf), and f1 changed from f1 to (f1+Δf). How can I assess the error caused by frequency fluctuation? In experiment, I have found that there was a difference between (f1- f0) and (f0-f1).
Thank you very much!
