I'm in FEM Mode and i try to reduce the time of simulation. I tried to modify all the parameters of the "Mesh/Refinement Properties"...
It's change not a lot... I must to look the number of point or the number of tetrahedral to know the time of simulation?
Thanks in advance
Best regards
BS
Thanks in advance
Best regards
BS
1. Minimum number of passes - this sometimes set to high which is not necessary. Change it 1 if possible.
2. Consecutive passes - Don't change this but remain it to be 1.
