Hello Everyone,
My question is simple, and perhaps not technical at all. I created a layout co-simulation which I sent to schematic via look-alike symbol. I chose the minimum pin-to-pin distance schematic units so I can use standard resistors, caps symbols in schematic. The issue is that component generated by Layout is relatively larger compared to the schematic symbols.
Does anyone know how to scale further? Check the attached picture and you can see the pads are a lot bigger than the schematic symbols even though I chose minimum pin-to-pin distance in schematic units.
Any tips will be greatly appreciated.
rjrodrig
rjrodrig
