Hello All,
I am using LabVIEW 2013 with GPIB interface. I am working on a project of TCT experiment in which we are using four devices i.e. keithley 2410,Frequency generator (Agilent 3352A), DC bias(Agilent E3632A) and CRO(Agilent DS07104B).These devices perform different task which are as follows:
KEITHLEY 2410
used for giving bias to diode
FREQUENCY GENERATOR
used to give square wave as a input
Amplitude-1Vpp
Frequency(pulse width)-200hz
Offset= -500mV
Output on 1
DC BIAS
compliance=0.126A
voltage=15V
CRO
Switch ON
Autoscale
Channel 1 ON
Trigger -falling edge for channel1
Timebase-open: nsec with respect to falling edge
falling edge-80nsec (channel 3)
Aquire:Averaging 1024
Time-base with waveform
Save waveform
So please tell me the commands to operate these Agilent devices.
KEITHLEY 2410
FREQUENCY GENERATOR
Amplitude-1Vpp
Offset= -500mV
Output on 1
DC BIAS
compliance=0.126A
voltage=15V
CRO
Switch ON
Autoscale
Channel 1 ON
Save waveform
I couldn't find the 3352A in my product lists. Is that an old device?
The E3632A is a power supply, currently supported. Information, including manuals, is here:
http://www.home.agilent.com/en/pd-835964-pn-E3632A/120w-power-supply-15v-7a-or-30v-4a?cc=US&lc=eng
The DSO7104B is an oscilloscope, currently supported. Information, including manuals, is here:
http://www.home.agilent.com/en/pd-1787452-pn-DSO7104B/oscilloscope-1-ghz-4-analog-channels?cc=US&lc=eng
The programming manuals generally include examples.
Al
