I have a HP 6032A power supply. I have a problem that bothers me for a few days. power is managed by labview and Teststand blocks. when I send commands value measurement voltage and current, the power supply is working properly sometimes and sometimes it déconne.Parfois when I send the command to read current or voltage, the ERROR LED lights and returns the measurement result, but then it does not respond properly, sometimes it returns the correct value sometimes it retoune 0. I have not understood why the LED lights, and why she responds strangely.
Thanks for your reply
Can you tell me the following information:
1. Can you check the error that you are getting?
2. Are you programming in SCPI or compatibility?
3. What GPIB interface are you using?
Thanks.
