BTW, I was involved with the design of this board. There are 2 versions, one with a 10MHz crystal, and one with 32MHz. The intent was a simple board that could show some more complex things if necessary. I still use it for demonstrations and training, even on the currently released analyzers.
Al
Thank you for the confirmation, I have previously seen pictures with the kit having a diskette and I wanted to know if the one that I had bought was complete without opening the manual seal.
Al
