I tried to run simulation. ADS keeps complaining that a symbol has 3 pins while the schematic has 4. I couldn't find that, even using selecting all pin method. after I delete all pins I can find on schematic, I re-place pins and regenerated symbol. guess what? still complain about the extra pin and won't run. can anyone help? please...
now I generated a new copy called sch...1, carefully copied circuit over without pins, then deleted the original sch. then copied sch1 to sch. and re-generated the symbol. seems working.
new problem is I can't delete sch1. how can I make it deletable?
(column 0 in de_delete_cellview)
Failed to delete design "Win_Semi_LNA_lib:WIN_LNA:schematic1".
Received exception from oaDMFileSys plug-in when accessing library Win_Semi_LNA_lib: #9009: Cannot destroy a locked Object, or an object with locked files
