Hai,
I using infiniivision 2000x series oscilloscope, here I want to SAVE the waveform in .CSV format and edit that file and RECALL the EDITED file. But in RECALL option, does not support .CSV format, so I need to convert that file into RECALL file FORMAT , e.g.,.h5 FORMAT,
Any response will be appreciated...
Thank You
Thank You
Download InfiniiView from the Agilent website. It is at: http://www.home.agilent.com/en/pd-2113078-pn-N8900A/infiniiview-oscilloscope-analysis-software?nid=-35491.1010837.00&cc=US&lc=eng&cmpid=zzfindn8900a
A free 30 day trial is available.
- Make your changes to the csv file
- Load the new csv file into InfiniiView
- Save the data into an hdf5 file
- Load the hdf5 file into your scope.
Good Luck
Al
