On the PSA the command CALC:MARK1:MODE POS would create a marker and position it to the center frequency.
On the PXA, if the marker is already on, the marker stays in its previous position.
How do I get the marker to move to the center frequency (assuming I don't know the frequency at that time and don't want to query it)?
TIA
TIA
From the front panel press Marker =>, then press Mkr->CF Or send SCPI CALC: MARK [1] [2] [3]…[12]:CENT
Remember, you can press the green Help button, then press any key and this pops up the help text including the SCPI commands for that key. Turn off the help with the Cancel (ESC) key.
Regards -
