Where do i get a manual with the visa commands(labview) SCPI(such WAV;SOUR;PRE?) as for DSO 7012B ,there are any helpful document to understand this command .
thank you :)
thank you :)
Choose "Manuals", and the "Programmers Guide" should be in the list.
You could also try Command Expert, which will guide you through the process of getting the commands and syntax right, and export code that should do what you want. Information on that is here: http://www.home.agilent.com/en/pd-2036130-pn-E2300/command-expert-11?nid=-33002.992473&cc=US&lc=eng
Al
