vrf Base Conversions
Question asked by VRFuser on Dec 4, 2002
The default preferences printer controls work fine for a .vee prog, but they don't seem to remain active once a run time .vxe is created and run.  How can I make sure the printouts from a .vxe are the same size as the original .vee?  Also, is there any way to change the default settings for Matlab figures.  They seem to be set for letter size printout but I want A4 without the operator always having to make a manual choice.
Ivan Edwards
Senior Engineer,
InfraRed Integrated Systems Ltd.,
Towcester Mill,
Towcester,
Northants (UK).
NN12 6AD.
Tel:   +44 (0)1327 357824
Fax:   +44 (0)1327 357825
Website: www.irisys.co.uk
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. InfraRed Integrated Systems Ltd. (IRISYS) does not accept responsibility for changes made to this message after it was sent.
Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by IRISYS in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
