I'm testing a generator and would like to test the phase coherency between pulses.
The first pulse is transmit pulse for the radar. Lets say it has a frequency of 3.1 GHz.
The second pulse is the receive pulse which will go to the mixer, at a frequency of 3.0 GHz.
Assume each pulse is 100 usec longs, and the PRI is 1 ms.
How can I check the phase coherency of these two pulses?
I have done radar pulse measurements on Agilent scopes, and doing this may require additional SW, such as MATLAB or VSA.
Al
