I just replace the attenuator on my 54810 scope and need to update the contact count. Does anyone know where to get infinium service disk to update attenuater vertical contact count.
Thanks'
Mickey
Thanks'
Mickey
You don't need the service disk, just follow these steps:
1. With a keyboard connected and the scope running, press
and end the scope application.
2. Use windows explorer and create a batch file called service.bat in the C:\scope folder.
The batch file contains:
d:
If exist c:\scope\bin\hp5481X.exe hp5481X scope /scope /hpib /service
If exist d:\hp5484X.exe hp5484X scope /scope /hpib /service
3. Go into the self test menu and check the box for service extensions.
4 Now select the pulldown menu for scope self tests and select "Atten Set"
5. Press Start button.
That should get you there I think. Launching the scope application with the /service switch is what does the trick.
Jay
