vrf Fw: Printing To File in Boldface
Question asked by VRFuser on Dec 11, 2002
Tab and returns are ignore in html......unless you use the html tags <pre>
</pre> to encase your text.
Example:
<pre>
g     f     d
     g     d     k
</pre>
The pre tag stands for pre-formatted text.
This combined with tables would provide a lot of flexibility.
For all those interested in web authoring, http://www.webmonkey.com is an
excellent resource.
From: Kathy Kiessling [mailto:k.kiessling@attbi.com]
Sent: Thursday, December 12, 2002 3:08 PM
To: VEE vrf
Subject: [vrf] Fw: Printing To File in Boldface
I see a lot of other people liked the HTML idea as well.  I also liked it
because I could easily include graphs (as jpgs) as well, and the company
logo!  Main drawback is that the Tab has no meaning in HTML and is ignored,
so data sheets tend to become tables.  The table concept is simple enough,
once you take a little bit to learn the rules about the tags (TABLE, TR,
TD).  But there were plenty of opinions on what a generic table looked like
that it was a challenge to write a generic GenerateTable function.
Kathy Kiessling
----- Original Message -----
To: <Shaun.Trussler@nokia.com>
Sent: Thursday, December 12, 2002 8:39 AM
Subject: Re: [vrf] Printing To File in Boldface
> I'd think there are several solutions to this.  I think the realy answer
> is.. 'it depends'.  It depends on the file format you are using and how it
> embedds the formatting information.
> I personally had chosen to write files as HTML.  They are small, load
> quickly, are and portable.  In that case, I'd insert the HTML tag <b>
before
> and </b> after the text in question.  If you're interested, I could post
the
> basics for getting an HTML file setup.
> Kathy Kiessling
> From: <Shaun.Trussler@nokia.com>
> To: "VEE vrf" <vrf@it.lists.it.agilent.com>
> Sent: Thursday, December 12, 2002 8:18 AM
> Subject: [vrf] Printing To File in Boldface
> Greetings:
> Anyone know how to set up the "To File" object print to a file in
boldface?
> I would like to selectively print values in boldface that fail a specified
> criteria (e.g.  if x is not a certain array of values, print it in
boldface
> when printing to file). I would like to avoid sorting through the file and
> doing this after printing. Thanks for any help.
> Regards,
> Shaun Trussler
> You are currently subscribed to vrf as: k.kiessling@attbi.com
> To send messages to this mailing list,  email
"vrf@it.lists.it.agilent.com".
You are currently subscribed to vrf as: KPAIR@CMNC.COM
