I'm trying to connect MSO7104A to PC with Windows 7. Agilent connection expert works fine, and agilent command expert seems to work also. I can connect and command the oscilloscope from Agilent command expert. But when I try to do a simple program with excel, the command expert add on seems not to work. I can see the command expert tab, and even edit a sequence. But when I press the "run" button no dialog widow appears, and nothing happens.
I'm using the command expert 1.2 version update 1
What am I doing wrong?
Thanks for your help!
