I've got a problem with ADS using a network license. Startup time is exactly five minutes, which is very frustrating.
I've checked the firewall rules and both ports needed for the license server are allowed for communication in both directions.
The license information tool and the license manager are able to retrieve the license properties without any delay. After 5 minutes, ADS starts without problems and everything works ok.
Any ideas how to troubleshoot the problem would be very welcome. Checking the firewall logs didn't show any blocked traffic, but the constant delay looks like some sort of timeout.
I suggest you contact Agilent EEsof EDA technical support directly.
The ADS Discussion Forum is a community created to allow you to communicate directly with other ADS users around the world and is designed to be a place to ask and answer other users’ questions, exchange ideas, and share tips and tricks for using ADS. The ADS Discussion Forum is not the best or primary means to contact Agilent EEsof Technical Support. Registered users may access ADS Support and Documentation by visiting http://edocs.soco.agilent.com/display/support/ADS+Support+Home
Joe Civello
ADS Product Manager
