I'm having issues getting the optimization function to work with StabFact. It worked once before but I can't recall exactly how I got the function to perform properly. Optimization however works for the nf(2) alone.
This is the error message: http://i.imgur.com/krSF5Xx.png
Any ideas?
Thank you.
Any ideas?
Thank you.
Otherwise it has to be a function call on your S-parameter, and as far as I can remember the
function calculating the stability factor is spelled differently. Check the doku.
Toby
