On a 3000X, is there a way to trigger on a read OR a write to a specific I2C address?
I want to capture all data to or from a specific chip. There's other devices on the bus, so triggering on just a START won't do it.
I can select either a read or write, but they are mutually exclusive. Perhaps I'm overlooking something?
-mark
-mark
Al
