Hi everyone,
I need help for all of you, to help in my important assignment.
I need to do temperature 3d graph plotting using vee programming.
Using 4x4 array sensor (so got 16 sensor here), output from the sensor is transfer to 3d graph according to their coordinates.
From the example in vee programming, the only put input from some formula not from the I/O input.
Anyone can help I really appreciate that.
Another point I might raise is that if your assignment is so important, you might have actually given us a little more information about your problem. Are you saying that you can see how to do the 3-D plotting but not I/O? If so then 'sensor' doesn't give us much to go on. What physical property are you sensing? What instrument is connected to the sensor? What interface is used to connect to the instrument - GPIB? serial/RS232? USB? LXI ( Ethernet )? Do you have a driver for the instrument provided by its manufacturer?
So, why not try asking again this time showing that you have expended some of your own valuable time & effort? Ask a question that we can answer such as "has anyone programmed an XYZ123 to receive 16 temperature measurements?" or "can anyone help me extract 16 pressure measurements from a PQR2000 meter?". This is generally an all-comers forum so we don't even mind "I have a PQR2000 meter - can anyone point me in the direction of being able to connect to the instrument over GPIB?".
