I am looking to transfer the s2p files from a PNA (eg: N5222A) into the connected PC.
My question is does "MMEM:TRAN? work with s2p files?
If it does then what is the right syntax to transfer the files using visa commands and through a GPIB.
Thank You.
Thank You.
Navigate to: programming->scpi->commands->memory->TRANsfer (or this link: http://na.tm.agilent.com/pna/help/latest/Programming/GP-IB_Command_Finder/Memory.htm#Transfer)
In that section there's a link to an example program that transfers a file to and from a PC and a PNA (a s2p file).
Here's the direct link for the example: http://na.tm.agilent.com/pna/help/latest/Programming/GPIB_Example_Programs/Transfer_Data_using_GPIB.htm
