when I use DSO1014A, pressing the [Auto-Scale] key on the front panel Continuous 2 times,CH1 CH2 CH3 CH4 Auto-Scale on the Dispaly .How can i do this in my program which use command to do the same thing?
I've never programmed the 1000 series of scopes, but the Programmer's Guide says that there are 2 ways to initiate Autoscale. First is the "AUToscale" command, the other is the "Key:AUTO", which emulates pressing the key.
If you want all channels to be checked and autoscaled, then you may have to turn them all on before issuing the autoscale command.
Al
Al
