I measured some data (delay between two output signal) with agilent MSO7104A Oscilloscope .
I save the result on USB( to csv file), and now I want to analyse them. when I open the saved file, I saw the second, are negative!! how it can happen .. can anyone help me how I can show the data : Here is some of the data :
x.axis X1 X3
1 second Volt Volt
2 -500.00E-06 -18.75000E-03 +0.0E+00
3 -499.00E-06 +12.50000E-03 -31.25000E-03
4 -498.00E-06 +12.50000E-03 -31.25000E-03
5 -497.00E-06 -18.75000E-03 +31.25000E-03
6 -496.00E-06 +43.75000E-03 +0.0E+00
7 -495.00E-06 -18.75000E-03 +0.0E+00
8 -494.00E-06 +12.50000E-03 +0.0E+00
9 -493.00E-06 +12.50000E-03 +0.0E+00
10 -492.00E-06 +12.50000E-03 -0.0E+00
11 -491.00E-06 +12.50000E-03 -31.25000E-03
12 -490.00E-06 +12.50000E-03 +31.25000E-03
13 -489.00E-06 +12.50000E-03 -31.25000E-03
14 -488.00E-06 -18.75000E-03 +31.25000E-03
15 -487.00E-06 -18.75000E-03 -0.0E+00
16 -486.00E-06 +12.50000E-03 -31.25000E-03
17 -485.00E-06 -18.75000E-03 +31.25000E-03
18 -484.00E-06 +12.50000E-03 -31.25000E-03
19 -483.00E-06 +12.50000E-03 +31.25000E-03
20 -482.00E-06 +12.50000E-03 -31.25000E-03
21 -481.00E-06 +43.75000E-03 +0.0E+00
BR,
Mozhdeh
x.axis X1 X3
1 second Volt Volt
BR,
Mozhdeh
Al
